Thread: CA: Check Engine Light for Smog Check Inspection Manual
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
  1. #1 CA: Check Engine Light for Smog Check Inspection Manual
    Hi Guys,
    The check engine light issue bit me yesterday as I was getting my car smog checked, but I was able to convince the technician that our cars don't have one from the factory.
    This prompted me to try to fix the problem at the root. There is a typo in the Smog Check Inspection Manual the techs use for procedures on checking various vehicles. There is a error in the book for our cars.
    I submitted a request to have the typo corrected. Hopefully we won't have this problem in the future (at least in California).
    Here's what I submitted to the California Air Resource Board:
    From Sylvia Morrow [smorrow@arb.ca.gov]
    I am forwarding your finding to the Bureau of Automotive Repair who write the Smog Check Inspection Manual and develop the testing procedures including exceptions.
    Chiang Patrick wrote:
    Dear Ms. Sylvia Morrow,
    I would like to bring to your attention there may be a typographical error on the SMOG Check Vehicle Reference Book (I don't know what it's called, but the one the SMOG technicians look up when testing a vehicle). This occurred when the tech had to do a visual inspection of the check engine light.
    It seems to me that all of the 1988 and 1989 (could also include 1990, 1991 models also) BMW E30 M3's with 2.3L 4 CYL engine that are US models do not have a factory "Check Engine" light indicator.
    This vehicle is different that standard BMW E30's of the same year (the standard ones have 6 CYL. and a different dashboard.)
    Each time an owner of this model vehicle goes to get the vehicle smog checked. The smog technicians always say there is a problem with "Check Engine" light indicator not being there. They assume the dashboard has been replaced. But this is not so.
    I am asking you to please look into this matter as it is very frustrating each time explaining to the technician that the car is original and there was never a "Check Engine" light indicator from BMW North America.
    If a vehicle owner is sent to a referee station it could cost even more money and time that it already does.
    Please let me know if I can assist in any way.
    Here are some quotes from other owners of this vehicle:
    "No E30 M3's i'm aware of had a check engine light. You should just have a check light. I hope you get your problem resolved. Normally, the biggest 'check' light problem is when people go get their emissions done and have to prove that the car does not have a check engine light."
    "Smog Check Fail: Message: It's OBD I exempt! There's no check engine light in the M3!!! somehow convince the tech that there really is no "Check Engine" light. It's an M3, not a 325i."
    "I need help. Just bought another ///M and failed smog due to no check engine light."
    "Go to the dealer and explain. They should provide you with something in writing, they did for me. Or take it to the dealer and have them do the smog check, less hassle running back and forth. Hope you get it worked out."
    "I live in California and as you all know we have a tuff smog law. They are saying that my 91 need to have a check engine light inorder to pass smog, I told them that non of the E30 M have such light. For all you 90's and 91's out there do you all have a check engine light? and also do any of you know where I can get the info that say so. The smog shop need it to pass me and if I dont have that can't get my new baby registered. I tried to call the local dealers and they dont know what the hell they are talking about. Let me know and thanks in advance."
    I need help finding some information on the 1988 M3. I'm currently trying to get my M3 smogged (California Emission Test), but they keep failing me. They say that my "Check Engine" light is not working. Therefore I won't be able to register it. I went to my mechanic and he says there is no check engine light. Does anyone have any info to back up my mechanic? I need to get this done to be able to keep driving it. Pls. help if you have any info on the instrument cluster (maybe a website or something that I can show these people)"
    "Well, seems like those smog idiots don't know much about this car, there is no need to explain anything to them and educate them about the car.
    Just tell them the flashing "CHECK" light at the center-lower part of the instrument panel (near the ///M logo) IS THE CHECK ENGINE LIGHT ! You can convince them more by telling them once you start driving the car, the light will turn off, if there's anything wrong with the emission control unit of the car, this light will REMAIN FLASHING !
    Don't tell them it's a "check brake" light, and don't tell them to step on the brak to disable the flashing. Because they will eventually step on the brake anyway, and the light will go away...then you pass the "check engine light" dilema.
    good luck"
    "I just went through the same crapola here in San Diego. The smog book/computer shows all e30' s have a check engine light. The first time I ran into this issue my mechanic who is an expert on e30 m3's didn't know either so we pulled the instrument cluster. Sure enough no light or wiring to the place where the bulb would be. Even at the referee station they said I had to get a signed note from a BMW dealership stating that it doesn't have a check engine light. I have the Electronic Troubleshooting Manual for my 90 m3 which clearly shows no circuit for a check engine light. The head of the service dept. at the local BMW dealer also owns an e30 m3 and he made me a copy of the same schematic page from a 90 325ic ETM (showing the check engine light circuit). Between my m3 ETM and the 325ic ETM page the referee station accepted that there was NO check engine light on e30 m3's. As a side note the dealership would have passed it but I had to go to a "Test Only Station". The first thing I do now when I go in for a smog inspection is to say "This car doesn't have a check engin light." Then we can fight it out without having to pay first."
    "This is a very common problem. I even had a so-called BMW expert here locally argue that if my car didn't have a check engine light that it must be grey market. Some people can't imagine that they don't know everything..."
    "My 91 M3 passed the actual California smog test at a Test Only station.
    But the tech failed me because he could not find Check Engine Light.
    I called BMW NA. The customer rep checked with NA tech.
    He called me back and told me M3 should have the CEL.
    Local dealer's master mechanic told me there is no connection for a CEL on a M3.
    I took car to a Referee station.
    Referee found, on the emission sticker in the engine compartment, "OBD EXEMPT".
    That means no Check Engine Light.
    Car passed smog."
    "I went through the same crap last year ... the smog guy failed me as I was trying to explain the "Check" (brake test) light to him from the owners manual. He said I had to take up with the referee which cost me extra. After running another smog check and referencing my owners manual he passed me. What a waste of my money and time!"
    "In the past, I think the guys doing my smog have always thought the flasing "Check" light (the one that goes out when you step on the brake) was the light because they've always said "Your check engine light is on... does it go off?" "oh... yeah (scramble into seat, step on peddle) SEE!!!" "Oh... OK..."
    Thank you,
    Pat Chiang
    Pat
    1, It says *CHECK* when illuminated, not "CHECK ENGINE".
    It is directing you to firstly check that there is hydraulic pressure in the brake circuit if the car has just been started.
    If the brake pedal is tapped, it is extinguished.
    If it illuminates a second time without the engine being switched off, it is directing you to the overhead diagnostic panel for an electrical anomality.
    2,The 1991 model year M3 was not certified for sale in California.
    3, I hope they understand that there are no OBD ports on these cars
    You're going to have to time your smog exams with someone who knows what they are doing.
    Hth,
    m
    I have been meaning to address this issue for some time. I actually worked for BAR for nearly 3 years in the engineering department. Since I was employed there, I was reluctant to make an issue over a vehicle I owned due to conflict of interest. My last inspection, I had to actually have my boss call the technician and set him straight. It was a pain in the ass...
    Let me know how your fight is going. I perhaps can offer some help. I still know all of the engineering dept. staff over there. There is an OBD Exempt sticker on the driver strut tower with an CARB EO#. This should be the exemption number issued by CARB when the car was certified. This should be case and point in the argument.
    Yes Mmark, I understand that the light is a "Check" panel light.
    The SMOG Book from the Bureau of Automotive Repair who write the Smog Check Inspection Manual indicates we have a "Check Engine" light, which we don't.
    My post is a request to change the error in the book, so future M3 owners will not have to convince the technician who references the manual that it is wrong.
    Thanks,
    Pat
    Pat
    Thanks Wookie,
    I forgot about the sticker. I'll send a reply mail to the ARB and see if the Carb exemption number will help. Keep you posted on the results, we'll see how much red tape is in the way to change the books.
    Pat
    Good luck, I deal with CARB daily. They can be, shall we say, troublesome at times...
    I've never had this issue and I've smogged the car 2x so far. At a test only station in Mountain View.
    This discusssion is very interesting. I deal with 2 CA test stations on a weekly basis. The "OBD1-exempt" sticker under the hood, should be documentation enough for the tech. - if he's on top of his game. You shouldn't need a note from the dealer or anything else - this is just an excuse on his part because he can't solve the delima on the particular E30M3. In their defense, they may have different levels of training (a "test only" tech is probably more familiar with the exceptions than the 76 station that does smog's as a sideline) BUT IN ALL CASES, the state has them convinced that they are the FINAL WORD when it comes to emission tests. The referee has the biggest head of all! They all love to be treated as "superior". So, with a little bit of knowledge & a lot of "yes sir, no sir", you should not have a problem. If you are looking for a E30M3, & run a lot of CarFax reports - CA registered cars can show some unique data. I've seen a number of reports on cars that show "fail smog" & then a "pass smog" on the SAME DATE ! Thanks to this thread, I now understand why.
    Seriously, as the other have said: the "OBD Exempt" sticker on the driver's side shock tower is your friend. They put that there for a reason.
    I just checked the '88 I bought last week and didn't see a "OBD Exempt" sticker or code on the driver side shock tower. I'll probably try and check my friends M3 and my other one.
    I don't know if I mentioned, but I did get the car passed at a "Test Only" place and only after talking to the guy for about 10 min.
    He checked my title to verify it was a salvage and thought the cluster might have been changed. I responded saying these cars didn't have a "Check Engine" light etc...
    He asked me if I was a CARB agent checking on his test only station. =)
    Looking for the code so I can send it to the Ca. Air Resource Board to change the books.
    Pat
    Pat
    Pat, it's on the sticker that shows the emissions devices for the car.
    It says "OBD Exempt" in the bottom left corner of the sticker. It's actually very easy to miss.
    Thanks Colin,
    I found it. Apparently the OBD Exempt wording is on the left side of the sticker and in tiny font on the right lower corner is the number: 2121906.
    Hopefully this helps others getting past smog. I've forwarded this over to the Air Resource Board.
    Pat
    Sure thing, Pat. I tried to take pictures but none came out very well.
    Good of you to take on this project. I'd actually heard about this problem for several years even before I owned an M3.
    I wonder whether other states will need this info in the future as their emissions stadards beome more strict?
    Sorry to bring this back from the dead, but could someone get the Executive Order number as it exactly reads on the strut tower?
    A picture would be even cooler. I looking into the issue at work and dont have my car nearby.
    Too bad not all of the E30 M3's have the "OBD exempt" sticker. I've seen them on some and not on others.
    "I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
