04-07-2005,05:27 AM
I like how thick that E46 rotor is, I'm sure it can dissapate much more heat that the stock units.
on the post earlier you quoted a price in the 1200 ish range... that is about the same price as a brembo kit from brembo. other than the this is cool all BMW parts (except for the spacers) what is the advantage to using used 8 series calipers over the brembo setup?
while typing this I thought of some pro's and cons
pro's
BMW discs, easy availibility
wide variaty of pads
no spacers for caliper
con's
used calipers
spacer is behing the wheel instead of on the caliper
did I miss anything?
p.s. jake I shot you a P.M.
Karl Kraus --Education is a crutch with which the foolish attack the wise to prove that
they are not idiots.
