Thread: Puddles of water in the driver's side after it rains
Results 1 to 6 of 6
  1. #1 Puddles of water in the driver's side after it rains
    I initially thought that these puddles were occurring because I just got my front and rear windshields replaced and the windows may not have been sealed properly. I went back to the glass place and we tried to locate the leak (using a hose) for about an hour. It turns out that the seal on the front windshield is fine. We noticed that the leak occurs whenever water enters into the outside vent on the passenger side. Has anyone had this problem before? Any tips/suggestions would be most appreciated. Thanks a lot.
    -Brett
    1990 M3/1998 M3 Sedan
    Northern VA
    dude i had a leak that collected under my driver carpet, by the pedals. and it turned out that the leak was coming from the front left fender area under the fuse box. check there for rust.
    A special thank you to:
    archie, chutrain, carfantiti, ///M3 Terr, Jake, G2NY, Justin(OKC), Andyman746, dllance, NameIsStanley, JP, Speedvill, blyguy, MTLALEX, ///M0F01SD, Tom64, GK-E30M3, L James, ///CRISS, Das Boots, e30polak, DrWillb, Cactusjacks1, E30terry, S14E30M3 and all the S14 members who have showed support and contacted me.
    Late Model 215BHP
    Remove the glove box and take a look up in the corner - its a fave rust area.
    This space is a sanctimonious shit-free zone.
    Make sure the plastic Vapor barrier behind the inner door panel on the drivers side door is sealing properly.
    m
    This occured to me on the passenger side, the intake vent for the HVAC system drain at the firewall for water is probably clogged with debris. Just clean it out. The drain is located on the passenger side of the firewall. Hope that helps.
  1. WTB: Front driver's side strut housing (or both)
    By C3 Motorsport in forum Parts
    Last Post: 11-21-2006, 06:43 AM
  2. Replies: 2
    Last Post: 09-28-2006, 12:24 AM
  3. WTB: Driver's side mirror
    By WillM3 in forum Parts
    Last Post: 08-02-2005, 11:24 AM
  4. WTB - Drivers side grill
    By Mick in forum Parts
    Last Post: 05-17-2004, 10:30 PM
  5. WTB - Drivers side fender and door
    Last Post: 05-03-2004, 04:56 PM
