Thread: Fog Light Assembly
Results 1 to 4 of 4
  1. #1 Fog Light Assembly
    M3 duh
    So i'm trying to replace the bulb in the passenger side foglight...to NO AVAIL! now that i have the trim ring removed, i removed one screw on the top left side of lamp. Now the lamp is tilting downwards, and i can't do anything else on it. Does anyone have a diagram of the assembly so that i can tell whats happening? Or a how to on changing the damned bulb - i did a search btw, lots of random crap out there.
    Thanks for the help in advanvce.
    Kaz
    "You must drive this car before you die, it really is that good." BMWCar Magazine re:the e30m3; Oct. 2002
    I just change mine today..pretty simple, unscrew the philips screw on both sides, frame should pop out. then gently pry one side of the foglight with a screwdriver. it should pop out aswell..then simply take the bulb off from the back. voila!!
    Ogi
    M3 duh
    That did the trick! sometimes i get nervous of "pry"ing on the car....now i hope the problem isn't the ground wire etc....
    Thanks Ogi!
    The problem I have is the fog light adjust is only for going up or down. My problem is the Left side (drivers side) is cocked left downward. Sort of a guy with cross-eyed. Is there a way to straighten the whole fixture?
    Lawrence
    BMW CCA San Diego Chapter #192742
    '89 325i M Technic - Gone But Not Forgotten
    '90 M3 AWII - Garage Queen
    '92 325i Cabrio 5 Spd - Son's DD
    '03 530i 5 Spd - SO's DD
    '05 330i ZHP 6 Spd - My DD
    '92 Toyota Previa - Ole Standby
    '03 Toyota Highlander - Daughter's & Grandkids Hauler
  1. Passenger side fog light
    By hubble1953 in forum Parts
    Last Post: 03-14-2007, 08:16 PM
  2. CA: Check Engine Light for Smog Check Inspection Manual
    By m3pat2 in forum General E30 M3 Discussion
    Last Post: 07-12-2006, 12:31 AM
  3. Rear fog light fitting?
    By neo2 in forum Lighting
    Last Post: 07-10-2005, 03:03 AM
  4. WTB: Turn Signals and Fog Light Holder?
    By K otiK M in forum Parts
    Last Post: 02-21-2005, 11:03 PM
  5. WTB: Complete Fog Light Assembly (Pair)
    By peter*g in forum Parts
    Last Post: 01-16-2005, 05:16 AM
