Thread: Tow Hook extending too much?
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
  1. #1 Tow Hook extending too much?
    It seems like the front tow hook is over extended that if I was to install the cover, that I would not be able to due not being flush. No, front has never been to an accident. I tried to have the bumper re-adjusted to be flush and yet to no avail. What gives? Thanks.
    Lawrence
    BMW CCA San Diego Chapter #192742
    '89 325i M Technic - Gone But Not Forgotten
    '90 M3 AWII - Garage Queen
    '92 325i Cabrio 5 Spd - Son's DD
    '03 530i 5 Spd - SO's DD
    '05 330i ZHP 6 Spd - My DD
    '92 Toyota Previa - Ole Standby
    '03 Toyota Highlander - Daughter's & Grandkids Hauler
  2. #2 Hook
    M3 US spec
    I have the same problem with my 88. I have a set of euro covers and can only get one on. I'm told it can be pushed back but it does not look like an easy task.
    Mine is the same way. Was thinking to cut it off and install one like the grand master Vlad has installed.
    88M3 henna
    73T100C
    97 540\6-Gone
    2008 MINI Clubman S
    I once found that the metal reinforcement washers behind the bumper core had fallen off while I had the bumper in storage. They are just rivited on. If this happens the bumper will sit about 1/4" further back. Maybe worth a look.
    When I had the bumper removed on Jacie's body shop to readjust to be flushed, the tow hook cannot be moved or pushed back. It is welded to main frame. We even tried to hammer it but decided to quit after a few blows fearing it would bend the frame or whatever damage it would cause. So, we reinstalled as flush and straight as we can...no luck, still the same.
    Lawrence
    Jake....would you be able to locate the reinforcement washers in the RealOEM? Or, are those part of the bumper core???
    Lawrence
    I had the same problem, Used a hammer and bent the tow hook downwards, now everything fits perfect.
    -Tony-
    1991 M3 10Km
    1989 M3
    BEGINS HERE
    us
    had the same problem. What I did was grind the part of the tow hook thats hitting the cover.I kind of made that arc flat..fits perfect now..
    hope this help!!
    Maybe some heat and a dead blow hammer might be able to spread the ring apart rather than knocking it back.
    Quote Originally Posted by chutrain View Post
    This does sound like a good idea to suggest, but I think we need to remind our friends here that heating and cooling metals hardens them. I can see this happening quite easily since some of us might already be feeling cold and more importantly windy weather. So probably the best approach to this potential method would be to heat the entire ring slowly and evenly and to do so in a warm garage or anywhere that would allow the ring to cool down as slowly as possible to prevent hardening. And personally I would exercise great caution if the desire to manipulate the ring arises after it has cooled down.
    HTH
    1989 M3 (till I die)
    1987 325iS (sold)
    1985 325e (sold)
    1984 318i (sold)
    Quote Originally Posted by Das Boots View Post
    I just had a look and it appears to be part of the bumper reinforcement.
    If we were able to find the problem what causes this tow hook to protrude out then we can fix the cause, right? Why do some M3 fits flush and some do not without modifications? I might be anal about this, but heating and beating the tow hook, or grinding it would destroy the tow hook's integrity? Heck, if that happens, might as well cut off/remove the tow hook?
    Lawrence
    Maybe past "towing jobs" have caused the tow hooks to elongate a little?
    Very possible, especially not knowing any past tow jobs by POs. But still a hook should not be elongating. Wondering if the hook is bolted in to the frame somewhere in which like a tongue that slides that we could not see vice being welded? Need further study.
    Lawrence
    Evo II
    There's no moving the tow hook, it's welded to the frame, mine was elongated, now it's gone. I figure I can pull it from the rear hook if needed. There's a shipping eye on the left side frame rail too, you'd need to take off the bumper cover to pull the car with it though.
  1. US Tow hook cover install
    By michollock in forum Wings & Spoilers
    Last Post: 09-18-2006, 05:03 PM
  2. painting euro tow hook covers...
    By noro in forum Wings & Spoilers
    Last Post: 09-05-2005, 07:10 PM
  3. stock airbox w/ tow hook cover..
    By arvzs1 in forum General E30 M3 Discussion
    Last Post: 07-23-2005, 11:30 AM
  4. Replies: 1
    Last Post: 08-05-2003, 10:28 PM
  5. Replies: 2
    Last Post: 05-18-2003, 11:34 PM
