Thread: Spark Plugs - Condition of Engine?
Results 1 to 4 of 4
  1. #1 Spark Plugs - Condition of Engine?
    I have included some photos of the spark plugs that I removed from my M3. They are not old plugs, but I am curious if anyone here can shed some light on the condition of my engine based on these photos:
    Thanks, Daniel.
    - 1987 M3 (e30)
    -- BeastPower Motorsports: www.beastpower.com
    - -Eisenmann Exhaust Systems: www.eisenmann.us
    From what I know they look good to me. Having some carbon around the base shows it's not lean and having a whiteish ground piece means it's not too rich. However looking at plugs is not the greatest method of diagnosing because they will always show the condition of the engine right before it was shut down, which is usually at idle.
    "It is needless to say that self-propelling vehicles, like other machines, will never do as much for one who does not understand them as for one who does."
    Daniel, Alpine is right. Plug reading is more an art than a science. You have to run the engine in the range you want to test, then shut it off and coast to a stop to really learn anything. Even then, unless things are grossly wrong it is hard to draw too many conclusions from plugs....
    Your plugs look more or less "normal", but as Alpine said it really only tells you that the engine is running OK at idle.....
    I think plug reading is a relic from the days of carburetors and AFRs that were only good enough to make the engine run. Now with computer controlled engines and all, I think plug reading is sort of outdated unless you are looking for things like oil in the cylinders, etc.
    A good wideband O2 meter will tell you much more about the mixture than the plugs can.
    Thanks guys! I appreciate the feedback. I didn't really expect to learn anything terribly interesting, but it is nice to know that there isn't anything that looks catastrophic. In rebuilding the car, I am working my way from the engine's electrical system, cooling system, suspension, drivetrain, brakes, then interior rust, exterior rust, cosmetics, and lastly will delve into the engine's condition. As long as the car seems to be running well, I prefer to handle it last.
    I appreciate the help. Cheers, Daniel.
    - 1987 M3 (e30)
  1. Problems with Turner engine!
    By whakiewes in forum Our Best Topics
    Last Post: 11-02-2006, 09:10 AM
  2. CA: Check Engine Light for Smog Check Inspection Manual
    By m3pat2 in forum General E30 M3 Discussion
    Last Post: 07-12-2006, 12:31 AM
  3. Pulled spark plugs, showing lean burn condition
    By M3Solo2 in forum Spark Plugs
    Last Post: 10-17-2005, 02:12 PM
  4. Here is a E30 with Corvette LS1 engine
    By M3inStockton in forum Engine Swap Cars
    Last Post: 03-15-2005, 02:29 AM
  5. spark plugs
    By John in forum Spark Plugs
    Last Post: 01-15-2004, 07:02 PM
