The following is a collection of parts that were going to be used to build a e30 Club Racer/Track Car. I have since changed the direction and am placing the parts on the market. They have been stored in a heated garage.
I wanted to give the S14.net group a chance at these. I will respond "on a first email basis" and will honor this as long as there is no negotiation on price once that process starts I reserve the right accept the highest offer or pull them off the market.
I would prefer to sell the parts as a complete suspension, or body, or electrical package - so please provide me an offer.
Please email me at e30V8@comcast.net for images and additional details.
Shipping Options:
1 Buyer to arrange shipping from 80528.
2 5% or $10 minimum packing/crating/pallet fee assessed on all sales above $200, unless picked up by buyer.
3 Seller can deliver within 200 miles of Fort Collins, CO for $.75/mile (one way).
4 Buyer pick-up in Fort Collins, CO
Payment Terms:
1 Parts and shipping to be paid in full before they are shipped.
2 Parts require 50% deposit if seller delivers or buyer picks up parts, remaining balance and applicable delivery charges due upon delivery/pick-up.
3 Seller will put the parts "on hold" for 10 days once deposit is received if parts are not delivered or shipped buyer will forfeit 50% of the deposit and the parts are on the market again.
4 If parts are not as represented 100% refund will be provided less ½ the return shipment fee. Refund will be given when parts are retuned.
5 Delivery fee will be assessed at time of part delivery.
6 Money Order, Cashiers Check, Pay Pal (3% additional charge) or Cash no personal checks.
Suspension and Brakes
$1850.00 BMW e30 M3 Front/Rear Suspension and Brakes Front 5 bolt hub and strut assemblies (L/R), Rear 5 bolt hub and trailing arm assemblies (L/R), Front and rear e30 M3 brakes calipers, rotors, brackets and rotors, front and rear sub-frames, diff to hub drive shafts, new front steal control arms. NOTE the M3 was hit the accident tweaked the front strut housing and rear trailing arm new front strut housing and undamaged replacement trailing arm is included (Will NOT separate)
$1450.00 Brand New BMW e30 M3 Ground Control suspension - Koni externally Single Adjustable (front and rear struts/shocks), GC coil over systems front/rear includes threaded collars and spring perches (Front and Rear), weld-in collars, H&R springs, racing bump stops, racing GC Camber Plates , CG rear shock mounts racing (Will not separate)
$300.00 BMW e30 M3 Hartge Sway Bars front and rear (Will not separate)
$200.00 BMW e36 M3 Rack and Pinion Assembly 14 to 1 ratio, great e30 upgrade
$125.00 Brand New Tree House Racing Front control arm pick-up points solid
$100.00 Brand New BMW e30 M3 Ground Control solid sway bar drop links front
$100.00 Brand New Turner Motorsports motor mount reinforcement and front strut to sway bar reinforcement kits (not installed)
$80.00 e30 M3 Brand New e30 rear poly sub-frame mounts racing
$50.00 e30 M3 Vacuum Booster
Body and Exterior
$1000.00 Brand New BMW e30 M3 fiberglass doors (R and L) Very light - 8 lbs each, right/left, very high quality uses stock hinge points provisions for stock glass. (Will not separate)
$475.00 Brand New BMW e30 M3 Front Bumper Cover w/EVO II extension urethane not fiberglass, very high quality and durable, not OEM (Qty 2 - $900 for the pair)
$250.00 e30 M3 Hartge (w/Hartge tag) single wiper setup, includes wiper arm and block off grill
$150.00 Brand New BMW e30 M3 Door Mirrors e36 M3 dual post style, power very nice
$220.00 BMW e30 M3 fiberglass hood used, but in good shape, pin mount
$220.00 Brand New BMW 2002 Turbo Fender Flairs allows 8.5 to 9" wide wheels with standard e30 body work.
$200.00 e30 M3 Front under-tray/diffuser front belly pan that starts at front spoiler edge and goes to front wheel wheels - OEM
$120.00 e30 M3 center/side grills, and Head light buckets center, right, left perfect
$120.00 e30 M3 Drivers side door correct M3 door (w/o impact strip) complete with glass, regulator, harness WHITE
$75.00 e30 M3 Tail lights right and left, perfect
$75.00 e30 Dashboard very nice shape, ½" long split at center to dash can not be seen from drivers seat, other wise perfect. Great for track car or daily driver.
$50.00 e30 M3 Roof Band piece that goes between rear raised roof and standard e30 roof about 1" in width, perfect, not bent WHITE
$25.00 M3 Jack, lug wrench and plastic trunk holder.
Wheels:
$350.00 17 x 8.5 ET13 Milli Miglia Wheels (Qty 4) straight, strong and light - good shape, e30 M3 offset or e24, e23, e34, e32 offset, will fit e28/e12 but will require fender rolling (SOLD)
Electrical
$200.00 e30 M3 Wiring harness complete car, less engine management harness, no cuts, includes wiring for heated door lock and wind shield sprayer nozzles
$75.00 e30 M3 Upper Steering column, includes all wiring, control stalks and a key, no cuts
