Thread: "Rose"
Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 136 to 150 of 188
  1. #136
    m3
    Quote Originally Posted by Alex Lipowich View Post
    If not, perhaps by then the race car will have its S54, and perhaps my power-to-weight and enormo tires and brakes will give me a chance to run you dogs down......
    uuuummmmm alex. I checked the video, i was running a ~1:50 at the extended gingerman (track felt green) and ~1:19 (manual steering) at blackhawk. If memory serves me correctly, your CM car was spinning blackhawk around 1:17. "run over us dogs" would be more factual. :(
    Quote Originally Posted by e30m3power View Post
    I bet that S54 pulls very nicely
    most definately. right foot very happy.
  2. #137
    Quote Originally Posted by new guy View Post
    Nice vids, I remember the days of running with you guys :(
    Maybe next year, I can play catch up
    Me too, plan to return for sure at some point next season
  3. #138
    Jason great stuff congrats. I can believe how appealing that S54 swap is. Makes the S50B32 swap look like ancient history. Euro engines are now so last year.
  4. #139
    Any updates you want to share?
  5. #140
    x2
    Need a good mechanic/fabricator/performance shop in SoCal?
    http://www.r3vlimited.com/board/showthread.php?t=155404
    Castro Motorsport
    12600 Sherman Way, Unit C
    North Hollywood, CA 91605
    (818) 765-3606
    The Purple ///Monster Build:
    http://www.s14.net/forums/showthread.php?t=47251
  6. #141
    x3
    91 M3 AW 2.5 CR Dogleg
    88 M3 AW Track Car s54
    95 525 Touring M52 Turbo
    04 Toyota Tundra
  7. #142
    m3
    just got a package of AST 5100's, e36 fronts, z3 rears. new hubs, bearings, etc.
    Also re-worked the rear subframe. I had the rear subframe lifted 10-12mm (which helped a TON) but I wanted to go up even farther. Mocked up a jig, and moved the trailing arm pickup points about 25mm. it just pokes through the rear deck. I am hoping to finish it up this weekend. will try to post some pics.
    cheers, Jason
    edit: forgot to mention i got a dual orbital last fall. had to try it on my not-so-shiney paint. wet sanded the whole thing, cut it, buffed it, then put it away.
    sand
    cut / buff
    fall pic in neighborhood
  8. #143
    m3
    New throttle pulley. Better than expected.
    Converting to throttle by cable is NOT as easy as I thought. After trying 5-6 different pulley / bell crank systems on the original build, I finally got the pedal to feel good. (it looked ghetto, but it worked well.)
    Fortunately for us, Alex has made some REALLY slick hardware.
    Tip in is perfect. No on-off throttle!
    Breeze to install, no interference.
  9. #144
    US with S54
    Looking good. I'm glad I kept the FBW.
  10. #145
    m3
    Last time out, I got a MAJOR engine vibration. I immediately thought it was the bearings. As it turned out, I distroyed the harmonic balancer. Apparently, the balancer should get a duct of fresh air to keep it cooler.
    I found a good balancer, replaced it, much better. However I still get an occasional VERY slight vibration. Not sure if its my brain playing tricks or if the bearings got cooked. I am getting ready to run a compression test and pull the pan to check the bearings. Any insight? cheers, jason
    pics of carnage...
  11. #146
    This has been a known issue going back to the euro3.0 and 3.2. The long 6cyl cranks have all sorts of harmonics at high RPMs. I lost mine on my 3.2 which shook the flywheel right off the crank. I contacted ATI a little while ago, to commission a custom damper for the S54. They were happy to make one for me, but at the exorbitant cost of $800+. I told them that there was no way I would fund their R&D for a product that would later retail for 3 or $400. They said that they might consider a volume discount, but I wasn't willing to shell out for the 25 or so units it would take.
    In the interim, we're stuck with preventatively replacing the OEM damper at the tune of $500 a whack.
    NASA GTS5 #945
    2009, 2011 & 2012 NASA GTS5 Midwest Regional Champion
  12. #147
    If anyone was going to arrange a GB for an ATI balancer I would be on that list. I too looked into these but the $800 price tag was too much for the current budget.
    Sam
  13. #148 Damper
    If anyone wants to run with this, here's an alternate. We know what ATI will do for us, maybe these guys have a more favorable option:
    Fluidampr by Horschel Motorsports
    180 Zoar Valley Road
    Springville, NY 14141
    (716) 592-1000 phone
    (716) 592-1001 fax
    Email: support@fluidampr.com
    I believe there is a market for the product, I just don't want to be the guy to finance the R&D.
    NASA GTS5 #945
  14. #149
    Is this damper thing a track car only issue or are all e46 M3's prone to it. First time I see that happen.
  15. #150
    any high RPM six cylinder is prone to the failure. Usually track cars experience the issue due to sustained high RPM/ high heat conditions, but it could happen to a street car as well.
    NASA GTS5 #945
