Thread: RMS Supercharger
Page 2 of 11 FirstFirst 123456 ... LastLast
Results 16 to 30 of 157
  1. #16
    Any videos of it running?
  2. #17
    318i
    Lots of pictures!
  3. #18
    Pictures of the installation, does it have an internal oil system or use the one on the engine, where do you mount the intercooler, are you supplying a chip or will an aftermarket ECU be required, what do you use for controlling fuel, etc.....
    Several E30 M3's.
    More than I need but not as many as I want....
  4. #19
    Looks like a vortech head unit, which one? Also, can you supply the crank pulley with a reluctor wheel (for crank sensor)?
    Several E30 M3's.
  5. #20
    318i
    Quote Originally Posted by inastrangeland View Post
    Pictures of the installation, does it have an internal oil system or use the one on the engine, where do you mount the inter cooler, are you supplying a chip or will an after market ECU be required, what do you use for controlling fuel, etc.....
    It get a circulating supply of oil. Oil is delivered to the Oil Injector that sprays the internal gears. Oil is then returned to the block. This system has proven to be super reliable. 200k plus miles on a Vortech blower is not unheard of.
    Setup with the air to liquid cooler ? The cooler mounts under the plenum, It is a weld on unit. The plenum can be restored back to it's original state down the road but it require welding, rework and refinishing. The alternative is to build a stand alone cooler in place of the plenum at an added cost of about 1500.00... Just an option.
    We will supply a chip and larger injectors to control the fuel. Ignition tables are
    re-calibrated. Also this system runs a Mass Air Flow Sensor, with air temp sensor for ambient temperature compensation. See pictures... If the job is done here, it includes a free dyno chip-tune..
    Crank speed and piston position are calculated at the flywheel, not sure why you want to do this up front. The head unit is a Vortech V2 SQ
  6. #21
    318i
    Quote Originally Posted by chutrain View Post
    No videos of it running... Sorry. This product was developed a long time ago and no one was taking video. lol
    Let me know if you guys have any more questions.
    -Chris
  7. #22
    Quote Originally Posted by THATDONFC View Post
    Some of us will be using a standalone ECU such as Megasquirt which has a MAP sensor and allows us to tune timing and fuel. The MS unit also needs a crank sensor input such as a 36-1 wheel. If I were going to do any FI, I would certainly get a better ECU than the stock one.
    Several E30 M3's.
  8. #23
    is this setup still aviable? i would love to be able to get this for m car. new or used
  9. #24
    -Chris
    Maybe a video can be taken now? Even idling?
    Will you have a step-by step instructions?
  10. #25
    318i
    The kit is available now. There will be step by step instrucions. We have an interested party. If he decides to bring the car down we will document and record all the steps. We will also have video of the finishe product along with pictures for the instructions. Hope this helps!
    -Chris
  11. #26
    Keep us updated on how the install goes.
  12. #27
    Is that Adam Corrolla's (sp?) car? I heard he had an RMS supecharger kit on his E30 M3.
    1986 Mercedes 190e 2.3-16 Cosowrth: http://www.youtube.com/watch?v=-JNJ-qVPBkU :wha:
  13. #28
    Wow... $3500 for the kit....looks nice.. how many labor hours are indicated for the install?
    Mark Williams
    Dallas, TX
    Nothing says "welcome to the neighborhood" like a search... oh wait... looks like they are all gone!
  14. #29
    318i
    Quote Originally Posted by M3 Adjuster View Post
    Because it requires that the head gasket be replaced, it will take anywhere from 2 to 3 day with out installing the cooler.
  15. #30
    rms tuning is bar none
    "Unlike the latter day E36 and E46 M3's, the
    original E30 M3’s main purpose in life was to
    win races on the track, not the street. It
    got the job done."
  1. Supercharger for S14!?
    By chutrain in forum Forced Induction
    Last Post: 05-27-2009, 11:49 AM
  2. RMS Leak?
    By Hank Cohn in forum General E30 M3 Discussion
    Last Post: 01-29-2009, 05:36 PM
  3. RMS Replacement
    By jonnys in forum General E30 M3 Discussion
    Last Post: 11-17-2005, 07:15 AM
  4. RMS leak questions???
    By Matts M3 in forum General E30 M3 Discussion
    Last Post: 11-15-2004, 02:33 AM
  5. Another supercharger question...
    By fritzintn in forum Forced Induction
    Last Post: 08-12-2004, 07:50 AM
