Thread: JOEBMW Motorsport: 88' M3 Restoration
Page 4 of 17 FirstFirst 1234567814 ... LastLast
Results 46 to 60 of 242
  1. #46
    Oh wow, your car looks beautiful already, I can't wait to see the finished product!
    What sets the e30 apart is that it set the precedent, the benchmark, for every "M" car since... - Top Gear
  2. #47
    Northern VA
    Joe those are some cool pics! love valve cover
    A special thank you to:
    archie, chutrain, carfantiti, ///M3 Terr, Jake, G2NY, Justin(OKC), Andyman746, dllance, NameIsStanley, JP, Speedvill, blyguy, MTLALEX, ///M0F01SD, Tom64, GK-E30M3, L James, ///CRISS, Das Boots, e30polak, DrWillb, Cactusjacks1, E30terry, S14E30M3 and all the S14 members who have showed support and contacted me.
  3. #48
    Euro M3
    how do you clean the throttle linkage ? it looks great!
    Nice work on the inside with SE parts.
  4. #49
    US-Custom
    Quote Originally Posted by jinkly View Post
    Well, first i degrease the parts. Then i first to sand each part by hand from 600 to 2000 sand paper. Cleaning the surface multiple times when sanding. Then going with a polish on the buff wheel. It take a lot of time.
    I was going to buff the complete throttle bodies themselves but i didn't as i thought it be a little too much.
    www.JOEBMWMotorsport.com
    JOEBMWMotorsport
    E30 M3 Rebuild Thread
    BMW & E30 M3 Parts and Services Specialist
  5. #50
    Euro M3
    Quote Originally Posted by JOEBMW View Post
    thanks
  6. #51
    Euro Spec
    Mine doesn't even look close to your ITB's after some time spent on it Stunning job restoring this beauty! keep up the good work Joe!
    M20B30 '87 Turbo / Euro M3 '87 NogaroSilver/ US M3 '90 / Euro M5 '93 / Euro M3 '87 LachSilver / Euro C43 AMG '98
  7. #52
    Euro Spec
    btw... That fuel regulator/pump is sitting just on front of the cam cover right? Or is somehhow connected the cam ? lol SOrry t ask this dumb question
  8. #53
    Looking good man! Hope we see it soon!
  9. #54
    US-Custom
    Quote Originally Posted by diegom6 View Post
    Yes it is a high pressure fuel pump. which is driven by the cam. I am running high fuel pressure to better atomize the fuel.
    Quote Originally Posted by BingM3 View Post
    Thanks...i hope too!
    JOEBMWMotorsport
  10. #55
    Sport Evo
    Joe,
    what pressure, injectors, engine management are you running?
    Steve
    Sport Evo No.47
    My Sport Evo Restoration
  11. #56
    US-Custom
    Quote Originally Posted by stevesingo View Post
    Joe,
    Steve
    Fuel pressure will be over 100 psi
    Injectors are 48lbs/hr
    ViPec V44 for the EMS
    Also, there is a custom dual sync sensor for cam and crank pickup on the exhaust cam. Running individual coils.
    JOEBMWMotorsport
  12. #57
    Joe, you may want to check the max rated line pressure for your injectors. Many risk splitting their cases at that pressure.
    2003 Mitsu EVO VIII - 2.0L / 600+whp
    1988 BMW M3 turbo - Work in progress. . .
    1986 SVO Mustang - Work in progress. . .
  13. #58
    US-Custom
    Quote Originally Posted by Ted B View Post
    Ted,
    Yes, that is a concern. I am using the Pro-Lite 350 Hose. This is the specs from summit racing..
    "Pro-Lite 350 hose is constructed in the U.S.A. of a tough, abrasion-resistant Nylon sheathing, banded to the textile inner braid embedded in the synthetic rubber liner. This gives the hose incredible flexibility, while maintaining the ability to withstand high vacuum and hot oil temperatures. It can withstand a maximum pressure rating of 350 psi, and an operating temperature range of -40 to +300 degrees F. The Pro Lite 350 hose can take the most demanding conditions and still deliver you to the winner's circle."
    So, it should handle up to 350psi. I will be no where near that pressure.
    BUT, i am considering running pipe for peace of mind (and also looks:gotcha
    I have to decide soon.
    I haven't had any bad experiences with the pro-lite 350. Have you? Other then pipe what are my other choices?
    JOEBMWMotorsport
  14. #59
    The line isn't the problem, but the injectors may be. The injectors themselves have a tendency to fail under excessive pressure, starting with splitting of the cases. They aren't designed for that type of rail pressure.
    You should check into that. One injector I know that can deal with 120psi max is the Bosch EV14 style. Most cannot.
  15. #60
    US-Custom
    Ted,
    You are absolutely right, everything needs to be able to handle the pressure safely.
    The injectors i am running are Accel 150148. I tried posting specs but the charts with all the data does not copy over nicely. You will have to look up the spec if you want to see them. Sorry.
    Accel says that they are rated to 125psi so that is my limit for fuel pressure.
    JOEBMWMotorsport
  1. Brazilian Project - US-spec 88 M3 !
    By GrandRoyaL in forum Project Cars
    Last Post: 12-21-2011, 10:28 AM
  2. FS:Original '88 M3 Zinnoberrot/Grey 142K Miles
    By m3cruzzer in forum Cars /Chasis
    Last Post: 09-14-2010, 06:26 PM
  3. Need advice on an 88' m3
    By M3'SRNICE in forum General E30 M3 Discussion
    Last Post: 01-02-2010, 10:11 AM
  4. Fs: 88 e30 m3
    By Rexer in forum Cars /Chasis
    Last Post: 08-31-2009, 03:46 PM
  5. FS: '88 M3 S50 swap
    By maxxfish in forum Cars /Chasis
    Last Post: 05-17-2008, 12:29 AM
