Thread: E30 M3 minor rust repair
Page 5 of 35 FirstFirst 12345678915 ... LastLast
Results 61 to 75 of 520
  1. #61
    Euro Spec
    AMAZING... I will definitely follow this thread... And cool rotisserie you got there :-)
  2. #62
    Man you should have filmed all this and put out an instructional DVD on how to rsto M3" along with a complimentary jar of vaseline to soften the final bill
  3. #63
    Ireland
    carrying on from where we left off last night, and it's on to the final of
    our 3 types of fillers. With the heavy fillers on and filler primer done and rubbed
    down it's time to break out the stoppers.
    After rubbing down the black guide coat on the shell and separate panels
    it's not uncommon to find some little tiny holes in the surface of the
    filled area. These are tiny little air bubbles that sometimes get trapped in the
    fillers as your spreading it on, and will show through the final top coat if
    not dealt with. Kinda hard to see them they're so small but since I can't
    figure out how to use the zoom on the camera your just going to have to
    shove your face up close to the monitor...
    along with these tiny holes, block sanding the guide coat also showed
    up a few larger blemishes that would also have to be dealt with....
    The last few larger one's shown above can be filled with a thin covering of fillers,
    but theres no point trying to fill the tiny pin holes with fillers, it just won't fit.
    So, we use this stuff....
    as you can see by the label 3M have decided to call it "Acryl Red Putty"
    probably cause they couldn't charge you enough if they just called it "stoppers".
    Basically it's just a very fine, runny, light form of normal fillers that
    has the advantage that it'll fit into any little scratch or pin hole. You can
    buy it in a tin or a tube like above. The tube seems to be handier for the
    simple reason that this stuff already has the hardner premixed in it, so
    the minute it's exposed to the air it starts to go off. With the tube you can
    take a little out at a time but the tin version seems to go hard after only
    opening it a few times. Then again I'm not exactly the fastest worker.
    So, squirt a little out to use...
    and apply it to the one or two pins holes on the car along with the
    thin coat of fillers for the bigger blemishes....
    well maybe a little more than one or two holes...
    if you ware spectacles it helps to clean them before this job or you
    may use half the tube before realising it's dirt on your glasses not
    pin holes on the car...
    the stoppers goes off fairly quickly and can be sanded away usually
    within 10 minutes. As it's so fine and light it sands much the same as
    the primer, so just gently rubbing it with some 320grit takes away the
    excess....
    to leave just the little bit filling the pin holes...(you'll have to take my word on it)
    the larger bits of normal filler take another small covering of guide coat
    and a light block sanding again to get them down flat....
    and with all that done around the shell and separate panels the bodywork
    is finally as flat as we can get it.....
    it's then time to clean up the....
    and start taping up for final coating of primer....
    as everything now needs to be coated fully in primer it's decided to break
    it down in to three sessions. First the underneath, inside, engine bay and
    boot and then later the outside and finally the doors and bumpers and other stuff.
    We decided to do it like this because theres just so much square footage
    of bodywork to be sprayed on the car it would be hard not to get overspray
    on panels that were starting to dry while your just getting around to
    spraying the area next to it. Plus with our magnificent, money no object,
    extraction system there was a good chance one of us would probably die
    from toxic fumigation.
    Got to spend a little time being precise taping the car up before hand as
    any paint that gets under it and on to the other half will show up when
    you spray over it later....
    1 inch tape around all the edges first....
    and then with that done, roll out the paper and fill in the gaps....
    quick once over with pre-cleaner, a swift wipe of the tac-rag, slop
    some paint together, fire it into the gun, and splatter it out on to the
    shell, leaves it looking like this....
    again handy having it on the spit for this part as you can turn it to any
    angle to help getting all the nooks and crevices inside and underneath....
  4. #64
    Ireland
    and when that was finished and dried the paper is whipped of and
    everything that was sprayed is now taped off ready for the second
    half to start....
    the window and door jams are all taped from the inside so as to
    allow full coverage right out to the edges....
    there is however one danger to watch out for when
    taping a car up from the inside....
    with all that done the final thing was to hang some paper down from
    the sills of the car. This is not to avoid overspray on the underneath
    of the car, thankfully we're not quite that anal, but instead to stop
    and spray travelling under the car and landing on freshly painted
    panels the far side....
    a wipe, tac, mix and splatter later....
    with the shell now fully primered we could move attention to the other
    bits, bumpers, doors, spoilers etc. However to do this the shell would have
    to go outside to make room, and we were worried that extreme temperatures
    of the Irish summer season might literally warp the metalwork!
    Yeah, as usuall it had been pissing rain solid for a week now....
  5. #65
    Ireland
    alas, just as we were about to abandon work on the M and start
    building an ark, the clouds broke and the sun shone through long
    enough to allow us to get this done.
    a few lengths of steel....
    spit dismantled....
    one short length of steel bolted to each spit stand...
    and some pimp daddy chain...
    allows us to hang the panels up for spraying like so....
    and some string from the rafters hangs the spoiler and mirrors.
    (spoiler worked out grand like this, mirrors were a disaster,
    imagine trying to spray an old grandfather clock pendulum, whilst moving,
    and you'll get the picture, you live and you learn)....
    the rest of the stuff went on what ever we could find to prop them up...
    started to run out of suitable props at this stage so had to borrow the
    neighbours wheelie bin.....
    had to be careful with that and tape it up good and proper as he's
    already fairly suspicious as to why the grass in his back garden
    has turned a funny shade of primer grey.
    bumper plugs are removed and done separately so as to allow the
    primer under where they shall sit....
    and thats it, the last of the stuff to be primered.....
    wipe, tac, mix, splatter and ta-daaaa....
    join us tomorrow evening to find out how things turn out as we
    take a turn to the darker side and start applying the Jet black.
  6. #66
    Washington D.C.
    Congrats on a great job thus far. I complain about not having the space to undertake such a project, but your project is a testament to doing more with less.
    My hat is off to you sir!
    Alles Beste!
    B. Wheaton
    1989 E30 M3, Owner since June 2000
    2008 E61 535xiT - The DD and work horse
    http://www.bayareamotorsport.com
    Register your E30 M3!
    http://www.bmwmregistry.com
  7. #67
    Ireland
    And finally the 3rd and final part to this update...
    We had decided right from the start of this project that the car would
    be going out to have it's top coat applied by a professional. The
    reasons for this were:
    a) i wanted the top coat and lacquer to be baked in an
    oven to get the finish as hard as possible.
    b) i wanted the finish to be fly free, ie. nothing stuck to the
    outside of the shell but paint, no dust, no flies, no stray pigeons.
    c) perhaps most importantly of all I wanted it painted by a
    professional. We've sprayed quite a bit so far on this car and quite
    a few rally cars in the past and in a moment we'll also be spraying some black
    to the interior and underneath of this one. But, there's a world of difference
    between spraying primer and spraying top coat. Spraying primer is fairly
    straight forward and your always going to be sanding it before the next
    coating anyway so the finish doesn't have to be mint. But top coat can go
    t*ts up in the blink of an eye if you haven't got enough experience to spot
    the signs that all is not well. After this much effort to prep it, I want the top
    coat to be as good as it can be and for that to happen it needs to be
    painted by someone with a lot more experience than me.
    That said, I'll be f**ked if i'm going to let someone else have all the fun, we
    were going to paint as much black as we could first.
    With the whole car now primered the bits we were going to paint black
    next would need to be sanded/ flattened. For the interior and boot we
    used these.....
    above is a 180 grit soft sanding block and below is a 220 grit
    sanding pad. They're much quicker to use than normal sheets of
    wet and dry paper and they'd do just fine to give a quick lick to the
    interior....
    the engine bay was a different story though. I'd spent a lot of time
    already sanding parts of the engine bay smooth and sanding down
    the seam sealer flat as I wanted the bay to look as good as the
    outside of the car. So now the primer in here was going to have to be
    guide coated and wet sanded with 600grit to get it mirror flat. Only
    the turrets, wheel tubs, chassis legs and front slam panel got this
    treatment. Not bothering going this far on the bulkhead as it'll be
    covered by the oem soundproofing.....
    and with that eventually finished it was time to shoot a couple of
    coats of blackness....
    very happy with how it came out, interior took it very well...
    the boot, as always,was a pure pig to do but came out well too.
    For anyone who's curious as to why a boot's a pig to spray, get yourself
    an empty kellogs conflakes box, stick your head inside it and then
    shove an aerosol can in there aswell and try to spray the inside of the box.
    You'll get the idea pretty quick.
    underside came out pretty sweet to....
    and then the engine bay, would all that extra sanding pay off???
    it looked like all that extra effort was worth while, the majority of
    the bay was silky smooth...
    all except that is, the f**king turret's and wheel tubs which was the
    main part I wanted to get right....
    I'd like to say I took this discovery in a cool and collective manner,
    but the truth is passers by outside had to cover there young children's
    ears for quite some time. What had happened was we had sprayed
    the underside of the car first and some overspray had blew up in to
    the engine bay and settled on the turrets. Unawares of this we then
    flipped the shell over and started spraying the engine bay. You could
    see it showing through as we were spraying but there wasn't a lot we
    could do then, so we finished and let it dry to see what it would look like....
    It's not terrible, but it's not what I wanted either. And the irony of it is
    it's only on the turrets and wheels tubs, the only part thats really noticable
    when everything refitted to the bay. So, what to do? well if you've read
    this far you've probably a good idea. After leaving the paint to fully
    cure the effected areas were wet sanded back down again with 600grit.
    Didn't have to go right back to the primer to get it flat although the areas
    do look grey in the pictures...
    each side was sanded back to a line or crease in the bodywork
    as it was going to have to be taped off to be resprayed and
    you don't want nasty tape/paint lines standing out.....
    So to also help blend in the resprayed parts, instead of just normally
    taping off the area, the masking tape was rolled like so....
    and then placed snug up against the seam....
    and another strip of tape softly over it to stop the roll unfurling....
    and repeat until all the area is done....
    the thinking behind this is that if you just taped it normally you'd get
    a noticeable line where the paint builds up against the edge of the
    tape, whereas this way some of the paint will fade in under the roll
    and if all goes well, make the line unnoticeable.
    With that done the rest of the shell needed to be taped up....
    and then mix a small bit of paint, spray it on, say 3 decades of the rosary
    and slowly open one eye to see if it's come up good....
    yipidy f u c k i n g doda....
    with that little episode over it was time to move on to the final
    preparation of the exterior and remaining panels for top coat.
    The reason this wasn't sanded along with the interior is if any
    overspray crept through the masking you could end up 15 pictures
    back up again and in serious need of sedation. Quick mask up
    to stop the nice black paintwork getting messed up by the coming
    wet sanding....
    and then head to toe every last square inch of bodywork left in
    primer gets powder guide coated and wet sanded with 600grit wet
    and dry paper....
    no scratches or blemishes to worry about this time just the need to
    get the primer as mirror flat as possible, any top coat can only be
    as flat as whats underneath it....
    bit of washing up liquid in the water helps the sanding go a little easier
    and cleans any stray contaminants off the panels as you go...
    this....
    took...
    forever....
    and...
    a day...
    or 3 weeks to be precise....
  8. #68
    Ireland
    but there is a small reward, with everything sanded so smooth
    you could now catch the light and see reflections on the panels
    and see how flat it'll look when black....
    and then with nothing left to do, the time had finally come for the
    top coat to go on. How was the black going to look? Would it
    come out ok? Was all this effort going to pay off?.....
    And i'd dearly love to be able to tell you all, but the simple truth is,
    we just delivered the shell to the bodyshop this morning and it'll be
    an agonising few weeks before we get to see the finished article.
    But at least now you know how I feel.....
  9. #69
    Sport Evo
    Oh the Joy of it all. Wait till you start putting the thing back together. My neighbours think I have Touretts.
    Looking good
    Steve
    Sport Evo No.47
    My Sport Evo Restoration
  10. #70
    Late Model 215BHP
    That, is simply amazing work ! I just wish I had the skill you have to be able to do that to my own bare shell resto project. I now see that when the time comes, it's going to cost me a fortune to have someone else to do almost exactly as you have done - so much detail work to get the end result perfect.
    Not just a great thread, deffo on of the best on any forum I've ever read.
    This space is a sanctimonious shit-free zone.
  11. #71
    Sport Evolution
    that is one hell of a resto! utmost respect to you! deffo the best one i've seen so far as your attention to detail is unbelievable.
  12. #72
    Euro spec EVO
    Excellent work
    More to see on www.fikux.cz
  13. #73
    Late Model 215BHP
    Did you have the shell dipped and e-coated all in one go ? If so, did this expose any problems that were hidden ?
  14. #74
    Ireland
    Yeah we did. Having the two processes done at separate times
    was never an option for us unfortunately. As the car and i reside
    in Dublin the dipping required we trailered it on the ferry over to
    England and left it there and then returned 4 weeks later to collect
    it when primer dipped. As it was, them two round trips cost us
    1200euro boat charges, another 1200 for two extra boats journeys
    to bring it home between dips would have well and truly broke the bank.
    We did consider making our own makeshift raft but the coastguard search
    and rescue service is pretty poor on that section of the Irish sea.
    As for exposing hidden problems upon return, I was fairly lucky (doesn't
    seem right using that word) in that all the rust on my car was fairly well
    developed and was easily identified and repaired before the dipping process
    started. So when the shell returned home, thankfully, there were no new
    "discoveries" of deceased metalwork. We also new the car had had a few
    coats of paint during it's life and that there was a bit of fillers used around the
    shell so we knew it was never going to be straight as a die when going to collect it.
    Didn't stop me from having nightmares in the mean time though, of receiving a
    phone call from SPL saying that what little of the car remained after dipping
    could be posted home if I wished.
    Are you thinking of having your shell dipped?
  15. #75
    Late Model 215BHP
    I was kinda thinking the travel costs would be a killer if you did. Reason I asked was because I found a lot of rot under the underseal that you simply wouldn't have known was there unless you had removed it first.
    It's a long story with my car, but yeah, I would like to do almost exactly as you have done by changing the roof, rust repairs and a quality paint job. Finding someone to do the job as well as you have is going to be tricky ....
    Look forward to seeing the final paint job and rebuild. Keep up the excellent work.
  1. MFest3 INFORMATION!!!!
    By yellow fever in forum E30 M3 Gatherings & events
    Last Post: 03-30-2009, 12:41 PM
  2. Which spring to install on 325 convertible with e30 M3 5 lug setup
    By Vazbro in forum General E30 M3 Discussion
    Last Post: 02-18-2009, 11:30 AM
  3. Replies: 5
    Last Post: 06-29-2008, 08:50 PM
  4. FS - E30, E30 M3 parts
    By punnzzells in forum Parts
    Last Post: 05-16-2008, 02:59 PM
  5. FS: E30 and E30 M3 Parts
    By Kevan in forum Parts
    Last Post: 03-27-2004, 04:57 AM
