07-06-2012,02:57 PM
Josh,
Absolute quality and clean work, as it should be !
Just a thought: I have noticed you placed the 02 sensor in my opinion further than the factory E34 M5. The factory E34 M5 is located inbetween the 'X' pipe or in your case 'Y' pipe.
I am attaching you a pic on the original e34 m5 'X' pipe
Note, the 02 Sensor is Facing against the exhaust gas flow.
I believe it will be more accurate and pass smog easier and as well performance wise. Not that were you put it on your current position will not work but not as efficient as it should. Not big deal to re-located it before the tune.
- 1990 E30 M3 DS Shwartz S38-B36 (3.6) Sold ! But never forgotten.
- 1990 E30 M3 DS Euro S38-B38 3.8 340hp. I promise, I will hide the 2 cyl under the dash which "Engine King". Mr. Paul Rosche took away to make the S14...
- 1988 E24 M6 Shwartz/Track Toy S38-B36 Goal is close to 50/50 I pushed the engine almost 15 inches for weight distribution will see...
- 1988 E24 M6 Shwartz/Natur, Daily driver.
- S38 is an addiction, enthusiastic manner and the perfect match for my E30 M3.
