Thread: The new guy..
Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 76 to 90 of 108
  1. #76
    E30 M3
    Getting the stereo buttoned back up. Head unit in and working all RCAs and speaker wires run, speakers installed and floorboard made for trunk sub mounting. Need to work on a nice mount for the amp and get the power wired up (waiting for Crutchfield to send me the corrrect amp) so I can test out and tune the sound then just waiting for the leather to put the interior back together.
    Drew
    1991 E30 ///M3 Brilliantrot
    1989 Toyota 4Runner Red
    2005 Lamborghini Gallardo 6spd Argento Luna Metallic
    2011 Audi TTS Ibis White Stage I
  2. #77
    e30 m3
    Who is doing your upholstery?
    Thank you,
    Hugo
    Photobucket
  3. #78
    E30 M3
    Quote Originally Posted by 88M3 View Post
    Thank you,
    Hugo
    If you look back through my thread I ordered a leather wrapped center console, arm rests and map pockets from Alexander Lenz out of Germany. My seats are in really good condition and needed no attention other than some cleaning but I wanted a bit more spice in my interior. Eventually I will probably do the entire door panel and rear pieces to match.
    Parts to be put in....
    Drew
  4. #79
    Quote Originally Posted by SKNKWRX View Post
    I am no audio engineer but wouldn't the sub and overall sound be much more effective if you cut the ski pass hole and faced it the other direction?
  5. #80
    E30 M3
    Quote Originally Posted by fronton View Post
    You might get a bit more bass but I am not cutting anything on this car so it isnt an option also I dont have a fold down armrest. Bass is non directional and low frequencies pass through solid objects so it will sound good. Hopefully. What you are seeing on the sub face is a passive radiator and the sub fires out the other side and into the corner.
    Drew
  6. #81
    E30 M3
    Stromung exhaust ordered.
    Drew
  7. #82
    you're going to love it.
  8. #83
    E30 M3
    Quote Originally Posted by c_tejuco View Post
    Sure hope so...better than a stock exhaust with holes rusted in it lol.
    Drew
  9. #84
    E30 M3
    Worked all Saturday on getting my amp mounted in the trunk. Wanted to get it installed with no mods to the car and managed to pull it off without putting so much as a single screw into any part of the car. Amp rack is pressure fit on top of the jack cover quite securely and when closed the trunk hinge holds it in place in case it tries to move. Also got the Infinity Basslink mounted and hooked up stereo is sounding pretty good even wthout any tuning as of yet.
    Mocking it up with cardboard
    Test fitting the parts
    Putting it together
    Drew
  10. #85
    E30 M3
    For a change instead of looking at it or working on it...I drove it to work on a 69 degree day in Chicago
    Drew
  11. #86
    GB SPORT EVOLUTION
    Looks good but there is something wrong about the drivers side dip beam light, is it sitting out a bit?
    GARY.
  12. #87
    E30 M3
    Quote Originally Posted by the bear View Post
    GARY.
    Dip beam? High, low, fog and turn signal which are you referring to?
    Drew
  13. #88
    GB SPORT EVOLUTION
    Dip beam = Low beam.
  14. #89
    E30 M3
    Ah ok, I am still fiddling with aiming the lights so I will take a closer look at it next time I am in the garage.
    Drew
  15. #90
    E30 M3
    Ordered suspension refresh today and a couple extras
    Bilstein/H&R Sports
    Susp Tech sways front and rear
    Reinforcement Kit (subframe, sways)
    Offset Strut mount
    Offset CAB
    Repair Shop rear shock mounts
    New tie rod assemblys
    Turner Motorsports ECU Chip
    UUC shift kit with shear selector rod
    Drew
  1. Replies: 25
    Last Post: 08-16-2003, 04:44 PM
  2. Talked to guy about buying his E30 M3 for 6.5k!!!
    By PublicEnemy in forum Purchasing
    Last Post: 07-05-2003, 11:31 PM
  3. E36 M3 guy needs advice on E30 m3 purchase!
    By marsfire in forum Purchasing
    Last Post: 04-05-2003, 12:47 PM
