Thread: VAC underdrive pulley kit
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Queens NYC
    Quote Originally Posted by Tom64 View Post
    Ah, keep it stock......Ha Ha
    Somehow I knew that was coming lol...
    1988 Diamantschwarz/Black
  2. #17
    Queens NYC
    Quote Originally Posted by jibbajabba View Post
    Take your pulleys off and have them blasted and replated. That will clean it up and should be less then $100.
    That's not a bad idea...
  3. #18
    Queens NYC
    Quote Originally Posted by ///schwartzman View Post
    The voice of logic... Ha ha... I just don't like to see good money go to waste when you could use it elsewhere for something that won't potentially cause issues in a 25 year old car that already has a mind of it's own.
    I had the entire set, including the crank pulley and they looked great but the only one I could really justify was the p/s pulley... so I sold them off.
    Very true..It wasn't the money that i was worried about..I figured i could dress up the engine and gain a pony or two while i was at it you know what i mean?
  4. #19
    Turbo S14 Spec
    Blast the stock ones and have them powder coated a sexy color or some fresh zinc...
    I don't know if your a/c still works, but I think i gained more "power" from shaving weight by getting rid of all the a/c components, swapping the fog lights for CF ducts and CF hood (in total @100lbs.) than installing the pulleys.
    Rich!
  5. #20
    I would actually like to see someone come up with a modern serpentine belt system (with automatic tensioning) for our cars. V-belts that have to be manually tensioned are so.....1980s. Too little tension they slip and drive you nuts....too much tension they break and wear out whatever they are spinning....
  6. #21
    I ran those VAC pulleys on my 320is. I like them. Bought another set for the M3. They're nice pieces. Even at lower revs (street) I never had an issue with the alt or coolant. Temp didn't move at all for me.
    Jake
  7. #22
    Queens NYC
    Quote Originally Posted by Jake View Post
    Jake
    Jake, do you have any pics of it installed?
  8. #23
    Euro
    Quote Originally Posted by Ironhead View Post
    It has been done.... But not the auto tensioner. All my pulleys are Micro Vee style. My build is incorporating a custom built steel crank pulley with timing teeth on the back and a new harmonic balancer. I have a DTM style water pump pulley, the power steering pulley will be off an E36 and I'm fitting a modified Honda alternator with a bigger, 80mm, pulley. I'll get some pics when I get a chance. The crank pulley isn't cheap, but if you want to go standalone I think it's a very nice piece of gear.
    "But most of all...
    ... I like the way you move......"
  1. WTB VAC crank pulley and underdrive kit
    By DH5507 in forum Parts
    Last Post: 07-19-2011, 11:36 AM
  2. WTB Alt pulley/fan and water pump pulley.
    By Audio4u in forum Parts
    Last Post: 03-16-2011, 05:38 PM
  3. Broken VAC Alternator underdrive pulley S14 BMW M3.
    By Newera in forum General E30 M3 Discussion
    Last Post: 11-24-2010, 09:03 PM
  4. Underdrive Pulley
    By Robert in forum General E30 M3 Discussion
    Last Post: 02-04-2008, 12:43 AM
  5. Experience with Underdrive pulley on S14?
    By 356racing in forum General E30 M3 Discussion
    Last Post: 01-25-2003, 11:01 AM
