What is this on the engine? - ///S14.net
Go Back   ///S14.net > Main Categories > General E30 M3 Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 11-28-2009, 02:08 PM
Patrick's Avatar
Patrick Patrick is offline
Registered
Send a message via AIM to Patrick
Model: US Spec
Year: 1988
Color: DS/Natural
Stock hp: 193hp
Displacement: 2.3
Stock
Primarily: Street and Track
usa
Just curious... I circled it in red. What is that? What happens if you loosen or tighten it? Mine is kind of loose.
Thanks for the help!
  #2
Old 11-28-2009, 02:18 PM
///CRISS's Avatar
///CRISS ///CRISS is offline
OG
Send a message via AIM to ///CRISS
Model: US
Year: 1988
Color: Diamantschwarz
Stock hp: 192HP
Current hp ~280HP
Displacement: 2.5L
Intake: Alpha-N
Ignition: Stock/A-N
Shocks: Koni SA
Springs: Eibach Blues
Primarily: Garage Queen
Idle screw
__________________
1988 Diamantschwarz
"The original M3 is utterly brilliant in ways the people at M have either forgotten about or choose to ignore."
  #3
Old 11-28-2009, 02:20 PM
MauiM3Mania's Avatar
MauiM3Mania MauiM3Mania is offline
Learner
Model: US Spec
Vin#: 2197550
Year: 1988
Color: Alpine II
Stock hp: 192
Displacement: 2.3
stuck
Differential: 4.10
Primarily: Street Car
usa
Quote:
Originally Posted by ///CRISS View Post
Idle screw
There are four of those, yes?
  #4
Old 11-28-2009, 02:21 PM
Dave @nz's Avatar
Dave @nz Dave @nz is offline
Registered
Model: Euro Spec
Vin#: wbsak05070xx932xx
Year: 1987
Color: Diamonschwarz/Silve
Stock hp: 200hp
Current hp 200
Displacement: 2.3L
Transmission: Dog Leg
Cams: Original
Original
Differential: Original Eur
Intake: Original
Ignition: Original
Shocks: Bilstein
Primarily: Collector
newzealand
Hi,
You have identified the idle speed adjustment screw, buy turning in or out the idle speed is increased or decreased. The screw is not ment to be tight the friction between the housing and the oring on the screw holds it in position.
Dave.
__________________
E30 M3 1987
Mini Clubman GT
BMW E36 323 Msport
Toyota Corona
KTM 200EXC
Honda CB50 (1979)
  #5
Old 11-28-2009, 03:00 PM
///Mflossin's Avatar
///Mflossin ///Mflossin is offline
GOD aka Zeus
Model: US Spec
Vin#: WBSAK0305J2197353
Year: 12/1987
Color: lachssilber
Stock hp: unknown
Current hp unknown
Displacement: 2.5L
Transmission: 265
Cams: E3/E2
Alpha N
Differential: 4.10
Intake: Carbon Fiber
Ignition: Stock
Shocks: Bilstein
Springs: GC/Eibach
usa
Quote:
no...
there is only one.
__________________
  #6
Old 11-28-2009, 10:25 PM
Mmark's Avatar
Mmark Mmark is offline
Skidmark
Model: US
Year: 91
Color: Diamantschwartz/iron oxid
Displacement: 2.3
Check the threads for idle adjustment.
There is more involved than simply messing with that valve.
m
  #7
Old 11-28-2009, 10:31 PM
///schwartzman's Avatar
///schwartzman ///schwartzman is offline
Gub-na
Send a message via AIM to ///schwartzman Send a message via Yahoo to ///schwartzman
Model: US
Year: 7/1987
Color: diamantschwarz-met
Stock hp: 192
Current hp ???
Displacement: 2.? L
Transmission: 265/5
Cams: EVO 272 / 264
MSII v3.52
Differential: 3.73 Quaife
Intake: Custom
Ignition: MSD DIS-2
Shocks: Bilstein Sport
Springs: H&R Race
jamaica
Idle Enrichment Screw, correct?
__________________
Rich!
'88 ///M3 (T)
"... get used to the view"
  #8
Old 11-28-2009, 11:17 PM
Patrick's Avatar
Registered
Model: US Spec
Year: 1988
Color: DS/Natural
Stock hp: 193hp
Displacement: 2.3
Stock
usa
I had the engine running when I would turn it and nothing would happen.
  #9
Old 11-28-2009, 11:31 PM
SONNYQ SONNYQ is offline
wizardwerkschi.com
Model: us spec e30
Year: 1988 DS,1990AW
Color: DS,AW, Henna
Stock hp: 321 hp, 195
Current hp 321hp,
Displacement: 3.2, 2.3
Transmission: Euro 6 spd
Cams: Schrick 284
Euro and U.S spec
Differential: 3.73
Intake: CF box
Shocks: Koni
Springs: TCKline
usa
idle
There is another adjustment up front that you have to loosen with phillips screw driver and adjust idle as well. You have to play with both to get your idle where you want it.
  #10
Old 11-29-2009, 01:05 AM
Patrick's Avatar
Registered
Model: US Spec
Year: 1988
Color: DS/Natural
Stock hp: 193hp
Displacement: 2.3
Stock
usa
Hmmm... Where is the other adjustment? Can someone please post a picture? I'm curious about this subject.
  #11
Old 11-29-2009, 01:15 AM
UweM3's Avatar
UweM3 UweM3 is offline
::dedicated::
Model: 195 Euro
Year: 1987
Color: JET BLACK
Stock hp: 195
Current hp 321
Displacement: 3.2
Transmission: S50 5-Speed
BMW ECU
Differential: 3:25
Shocks: Bilstein Grp N
Springs: KW 680/1030
Primarily: Track Car
uk
for a start, idle is controlled by the ECU and the idle value on the chip.
All the hardware on the engine is to allow to let the engine idle at the value set in the chip and to keep it there + / - a little
There is NO other screw to adjust idle. There is a CO Idle enrichment screw on the AFM (little round plastic cover with an allen screww deep down)
To adjust idle and CO you need to:
--disconnect O2 sensor
--disconnect trhottle switch and shorten all thre terminal in plug of harness
--attach Gas analyzer and set CO
--turn screw in picture till idle is withing specified range
thiis is not just a simple "turn it up and it idles quicker" screw. All you do is to allow enough air flow to the ICV (=idle control valve). Idle itself is then stabilised and controld by IVC and ECU.
__________________
In Memory of TJ, rest in peace my friend. You are sadly gone but never forgotten.
  #12
Old 11-29-2009, 11:11 AM
Patrick's Avatar
Registered
Model: US Spec
Year: 1988
Color: DS/Natural
Stock hp: 193hp
Displacement: 2.3
Stock
usa
So did I change anything by tinkering with just the screw while my engine was running? All I did was turn it from left to right a number of times to see what it did.
  #13
Old 11-29-2009, 02:39 PM
hardtailer's Avatar
hardtailer hardtailer is offline
Registered
Model: Euro
Year: 1986
Color: Lachssilber
Displacement: 2.3
no (as you probably noticed yourself too)
__________________
  #14
Old 11-30-2009, 12:39 AM
Patrick's Avatar
Registered
Model: US Spec
Year: 1988
Color: DS/Natural
Stock hp: 193hp
Displacement: 2.3
Stock
usa
Just making sure! Thanks guy's.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Thread Thread Starter Forum Replies Last Post
Standard engine rebuild xworks General E30 M3 Discussion 19 12-11-2007 09:32 AM
Problems with Turner engine! whakiewes Our Best Topics 212 11-02-2006 10:10 AM
CA: Check Engine Light for Smog Check Inspection Manual m3pat2 General E30 M3 Discussion 21 07-12-2006 12:31 AM
engine failure hardtailer General E30 M3 Discussion 17 04-06-2005 12:31 PM
Here is a E30 with Corvette LS1 engine M3inStockton Engine Swap Cars 13 03-15-2005 03:29 AM
All graphics and images are © Copyright s14.net 2008. Do not copy without written permission.
This site is soley funded for 2010 by our caring members listed below. Thank you! (Brackets denote years of sponsorship)
Magnus (8), Markus (3), Jake (3), Nick-NY (2), L.James (3), HANDBLT (3), Ironhead (3), wld_tony (3), Jimmy P. (3), UNHCLL (3), e30m3power (3), PRustan (3), d2a4 (3), Noro (3), 99m3riverside (2), Lionel (2), Mick (2), Vlad (2), 1990m3 (2), ShiftBMW (2), ALEXW (2), lockolose(2), JeffNJM3 (2), Evosport (2), GruppeAm3 (2), ///M3 Terr (2), OZM3, dllance (2), Chutrain (2), UweM3 (2), Aaronmjr (2), Cactusjacks1 (2), Az in Oz (2), Low Level (2), ///Mflossin (2), Lazyass349 (2), NSM3 (2), JOEBMW (2), Pecsok (2), UweM3 (2), M3Driver, BMWCAW, ANDERS, Ron //Man, Bimmertc66, YourBimmer, MasterShake, GK-E30M3, NickN3, NJboy, GruppeAm3, mtony, AndrewK, B Marques, Bman, Adroit, Matts M3, The///MadCircle, Das Boot, M3wannabe, ///M3-4Life, MR 325, Toast, Yamez RS, the bear, MauiM3Mania, david55838, M drei 88, KoenigsbergM3, Mpassioned, Junkyard_Sal, beemer_rider, Spulen81, Lil Lucas, Mdriver, Yan, mm1854, Kevnj, 02fanatic, techterr, Bennetts22, rewilfert, M-technik-3, MYTQUIK, walter boggs, bushido325, bigturbofan, EDOM3, JPCHAN, evommm, TR-Spider, 1988E30M3, 89trackM3, GeoS, luve30, Court M3, JOEBMW, Jeremiah, BBS 16, jimmyC, ColinM, MTREE, MichaelM3, Ryan M
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
