VAC S14 Pulley Kit - ///S14.net
Go Back   ///S14.net > Main Categories > General E30 M3 Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 03-26-2007, 05:11 PM
Mick Mick is offline
hack
Model: US
Year: 1990
Color: Diamantschwarz
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
Primarily: Track Car
usa
VAC S14 Pulley Kit
I got my VAC pulleys and they look great.
The install was a breeze as expected but I did run into a very slight interference problem with the PS pulley.
As you can see here the over sized pulley just slightly rubbed the bushing on the bracket.
I took a little material off of the sleeve and it's all good now.
Here are a few pics with size comparisons.
I took measurements but don't have them with me. From what I remember the diameter PS and ALT pulleys are
about 13mm larger than stock.
I don't have any info on the water pump. There was a packing mix-up with my shipment and I got 2 PS pulleys
and no WP. The folks at VAC have been very helpful and are sending me a new pulley straight away.
__________________
COM Sports Car Club | Maintained by VSR
  #2
Old 03-26-2007, 05:49 PM
UofOm3's Avatar
UofOm3 UofOm3 is offline
THUNDER|auto-edit||auto-edit||auto-edit||auto-edit|
Send a message via AIM to UofOm3
Model: US Spec
Year: 7/89
Color: redish/black
Stock hp: 195
Current hp not running
Displacement: 2.5
Transmission: 265/5spd US
Cams: Schrick 284/276
A/n
Differential: 4:10us
Intake: CF Intake
Ignition: GSP Wires
Shocks: Koni Adjustables
Springs: H&R Rennen Grp. G
Primarily: Garage Queen
usa
thanks for the info on these mick! Keep us posted!
__________________
1990 e30 m3
2001 e53 X5 4.4i
  #3
Old 03-27-2007, 09:54 PM
Jake's Avatar
Jake Jake is offline
Super Moderator
Model: Project M3
Vin#: Pending
Year: N/A
Color: Primer grey
Displacement: 2.7
Transmission: Grp A
Cams: ?
A/N
Differential: Various
Intake: CF
Ignition: Stock
Shocks: Leda
Springs: H&R
usa
Hi Mick. I think the power steering tension adjuster bracket is supposed to be turned around the other way so the adjuster nut is at the top and the pivot is at the bottom. Am I mistaken?
Cheers,
__________________
  #4
Old 03-27-2007, 10:18 PM
hack
Model: US
Year: 1990
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
usa
Jake,
You had me convinced for a minute, but I took a look at the ETK and it is correct.
http://www.mydig.com/auto/posts/ETK_psbracket.gif
I also found this pic. I don't know who's motor this is but you can clearly see how much more clearance the stock pulley has
http://www.s14power.com/gallery/bild...Engine_012.jpg
__________________
  #5
Old 03-27-2007, 10:23 PM
Magnus's Avatar
Magnus Magnus is offline
Administrator
Model: U.S. spec
Vin#: WBSAK
Year: 1988
Color: Lachssilber/Silver
Stock hp: 200hp
Current hp 200.01
Displacement: 2.3L
Transmission: 265/5us
Cams: Evo II exhaust
JC chip
Intake: EVO Airbox
Ignition: Stock
Shocks: Koni
Springs: Ireland stage III
Primarily: Street Car
usa
Thanks for the tips Mick!
__________________
Disclaimer: Remember, I know absolutely nothing, but it doesn't prevent me from having an opinion or suggestion. :
  #6
Old 03-28-2007, 05:47 AM
Jake's Avatar
Super Moderator
Model: Project M3
Vin#: Pending
Year: N/A
Color: Primer grey
Displacement: 2.7
Transmission: Grp A
Cams: ?
A/N
Intake: CF
Ignition: Stock
Shocks: Leda
Springs: H&R
usa
LOL Ok. Then mine is backwards! :p I wonder if this gives me more or less room?
__________________
  #7
Old 03-28-2007, 09:14 AM
hack
Model: US
Year: 1990
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
usa
Haha, nice.
I'm going to take a look this weekend. I'm sure it would fit the other way, but it may be a problem with the rubber bushing on the block side. I'm not sure how it will affect the bracket if you change vibration dampening point.
When I removed my >1 year old alternator bracket it was cracked in 1/2 on the toothed side just before the adjusting bolt. This will be the 3rd one I replace in 4 years for the same fracture.
When I removed the original PS bracket it was in fine shape. I know the leverage and stresses are different between the two, but maybe the rubber bushing also helped.?.
__________________
  #8
Old 03-29-2007, 08:55 PM
Modena 1's Avatar
Modena 1 Modena 1 is offline
Registered
Model: NYC
Year: 1990
Color: Brilliant Red
Displacement: 2.3
Did I miss something?
Mick - they just look "great"? How about a review? I guess you are waiting to install the WP pulley before a review?
  #9
Old 03-29-2007, 10:50 PM
hack
Model: US
Year: 1990
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
usa
You missed a group buy
http://www.s14.net/forums/showthread.php?t=24054
I'm still waiting on the water pump pulley so I haven't run the car with them. I don't think there will be much more to say than they look nice. If I said I felt a difference I'd be lying
__________________
  #10
Old 03-31-2007, 08:18 PM
hack
Model: US
Year: 1990
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
usa
Got the WP pulley.
Also, when installing the Alt pulley you need to ditch the 2 spacers to get proper alignment. The stock pulley was a 2 piece stamped plate design and needed the spacers for offset and to keep the plates rigid. With the VAC being 1 piece they aren't needed.
__________________
  #11
Old 04-01-2007, 12:29 AM
Jake's Avatar
Super Moderator
Model: Project M3
Vin#: Pending
Year: N/A
Color: Primer grey
Displacement: 2.7
Transmission: Grp A
Cams: ?
A/N
Intake: CF
Ignition: Stock
Shocks: Leda
Springs: H&R
usa
Great write up Mick. I'll be installing mine today.
__________________
  #12
Old 04-01-2007, 01:17 AM
autox320's Avatar
autox320 autox320 is offline
Registered
Model: US
Year: 1988
Color: DiamondSchwartz
Stock hp: 195
Displacement: 2.3L
Transmission: US
Maxx Alpha-N
Differential: 4.45
Intake: CF 18cm
Primarily: Street and Track
usa
Sweet! I must of overlooked these on Vac's page, ordering mine this week.
__________________
Photo album
  #13
Old 04-01-2007, 08:32 AM
///Mflossin's Avatar
///Mflossin ///Mflossin is offline
GOD aka Zeus
Model: US Spec
Vin#: WBSAK0305J2197353
Year: 12/1987
Color: lachssilber
Stock hp: unknown
Current hp unknown
Displacement: 2.5L
Transmission: 265
Cams: E3/E2
Alpha N
Differential: 4.10
Intake: Carbon Fiber
Ignition: Stock
Shocks: Bilstein
Springs: GC/Eibach
usa
Great Stuff Mick.....have you noticed any benefit at all other than aesthetics?
  #14
Old 04-01-2007, 09:57 AM
hack
Model: US
Year: 1990
Displacement: 2.3
Intake: Alpha-N
Shocks: Bilstein
Springs: J-Stock
usa
In an earlier post I told Modena I'd be lying if I said I felt a difference. But the car really did feel nice after installing these. I did make some other small changes at the same time though (new wires, removed intake muffler). So who knows.
Overall I'm very happy with them.
__________________
  #15
Old 04-02-2007, 01:42 AM
Jake's Avatar
Super Moderator
Model: Project M3
Vin#: Pending
Year: N/A
Color: Primer grey
Displacement: 2.7
Transmission: Grp A
Cams: ?
A/N
Intake: CF
Ignition: Stock
Shocks: Leda
Springs: H&R
usa
Hey Mick. I just installed mine last night. Oddly enough, the factory manual has the bracket the other way around (opposite of what the ETK shows). However, your method works best. I tried it the other way and the pulley rubs on the adjuster arm. I chopped a small flat section off the rubber bushing and mounted it like you described and viola! Good to go.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Thread Thread Starter Forum Replies Last Post
GB: VAC S14 Pulley Kit Jake Group Sales 16 03-29-2007 07:09 AM
VAC top secret 300hp s14 wld_tony General E30 M3 Discussion 19 12-18-2006 02:26 PM
Interest in S14 Turbo Kit?? TCD Turbo Forced Induction 34 01-02-2006 03:50 AM
FS: Complete VAC Motorsports Dry Sump kit Drevaen Parts 7 11-25-2005 01:24 PM
Experience with Underdrive pulley on S14? 356racing General E30 M3 Discussion 0 01-25-2003 12:01 PM
All graphics and images are © Copyright s14.net 2008. Do not copy without written permission.
This site is soley funded for 2010 by our caring members listed below. Thank you! (Brackets denote years of sponsorship)
Magnus (8), Markus (3), Jake (3), Nick-NY (2), L.James (3), HANDBLT (3), Ironhead (3), wld_tony (3), Jimmy P. (3), UNHCLL (3), e30m3power (3), PRustan (3), d2a4 (3), Noro (3), 99m3riverside (2), Lionel (2), Mick (2), Vlad (2), 1990m3 (2), ShiftBMW (2), ALEXW (2), lockolose(2), JeffNJM3 (2), Evosport (2), GruppeAm3 (2), ///M3 Terr (2), OZM3, dllance (2), Chutrain (2), UweM3 (2), Aaronmjr (2), Cactusjacks1 (2), Az in Oz (2), Low Level (2), ///Mflossin (2), Lazyass349 (2), NSM3 (2), JOEBMW (2), Pecsok (2), UweM3 (2), M3Driver, BMWCAW, ANDERS, Ron //Man, Bimmertc66, YourBimmer, MasterShake, GK-E30M3, NickN3, NJboy, GruppeAm3, mtony, AndrewK, B Marques, Bman, Adroit, Matts M3, The///MadCircle, Das Boot, M3wannabe, ///M3-4Life, MR 325, Toast, Yamez RS, the bear, MauiM3Mania, david55838, M drei 88, KoenigsbergM3, Mpassioned, Junkyard_Sal, beemer_rider, Spulen81, Lil Lucas, Mdriver, Yan, mm1854, Kevnj, 02fanatic, techterr, Bennetts22, rewilfert, M-technik-3, MYTQUIK, walter boggs, bushido325, bigturbofan, EDOM3, JPCHAN, evommm, TR-Spider, 1988E30M3, 89trackM3, GeoS, luve30, Court M3, JOEBMW, Jeremiah, BBS 16, jimmyC, ColinM, MTREE, MichaelM3, Ryan M
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
